hedgerow specialist...
Hi all, doing a bit of cleaning on the rear swing arm and went to put wheel back and Dam threads knackered on axel bolt:( , got me little file out to clean start up but nut knackered .
Anyone local got any spare either nuts or axel , sure they are common on most Alps and xrv even maybe a Domi or xl.
Last year when fitting chain and sproket we had to cut some off the bolt as it was siezed in swingarm - [lack of maintenance ] hence clean up and re grease axel with lithium grease.
You just may be in luck... as having just changed my rear end from drum to disk, I had to buy another spindle so that I could hold of some spacers to fit my new wheel... so, I have a spare spindle which I was going to put back on Ebay to get my money back.... but make me an offer and it's yours (originally paid £15 + p&p, about a month ago...).
Below are pics of the spindle I've just took which show how long it is, and how long the thread is, but you could always use a tap/dye set and cut the thread longer if needed... and yes the nut is included....:thumbleft:
Titch..:blob:
cheers Titch.
My neighbour who now has tallents I didnt know about:rolleyes: , we filed the spindle with a small file and then re cut the threads:p and he had a huge box of nuts:rolleyes: so have something to keep me going .
Thanks for the offer and best luck on E bay
Russ
No probs mate, always happy to offer any help if I can.
Titch:thumbup:
