The rear shock on my RD04 is really harsh at holes and bumps, and it goes thru the whole bike.
Its feels like the compression damping is too hard. I have tried to adjust it, but I can’t feel any difference.
I have 30 mm free sag, and 70 mm rider sag, so the spring should be ok. (from the 10%/30% rule, I have calculated the spring to be 9% too stiff, but I don’t think this is causing the problem).
My RD04 is modified a bit, so the fully fueled weight is 210 kg, and the weight on the rear wheel (with 10L missing in the tank) is 100 kg.
The big question is now: Should I go for a rebuild of the original shock, or should I find an aftermarket shock in the cheap end (YSS, Hagon, Wilbers Ecoline)?
If it is going to be a new shock, I will spend around 400€ on it.
It is the best gravel road and offroad performance and comfort I am looking for. I almost only use the bike for gravel roads and offroad, and road transport to find it ?
/Peter
/Peter
