I think the sprocket carrier uses the 6204, and remember that there should be a separate bush on the inner diameter, which brings the ID down to the axle size. The bush forms a spacer between the carrier bearing and the wheel bearing.
:happy11:
You are not wrong. You can do about 65 miles without it before all three sets of bearings on the wheel and sprocket carrier explode.Item 13 in the fiche is important.
You wouldn't have a spare one I can replace once I have rung Dave Silver and ordered one, would you?
