1 - 13 of 13 Posts
6203 2RS SEALED BEARING 17X40X12mm
6303 2RS SEALED BEARING 17X47X14mm
Are these correct for a 2003 XR250 ?
99.9% sure they are correct but wanted to check before ordering.
Red Blooded Biker
Give the parts dept at Fowlers of Bristol a ring on 0117-9770466 as they are very helpful with this sort of question.
Wasn't planning on getting them from a stealer, there are some decent bearings on fleabay which will do nicely, just wanted to check dimmensions but no matter will pull old ones out and measure them.
Red Blooded Biker
I meant ring Fowlers & ask what size/code number the bearings are as they don't mind helping out with technical info like that.
I always buy my wheel bearings from a local bearing specialist...usually SKF or Timken.
Stone Crazy
simplybearings
good prices and you can select the qaulity of the bearings
Discussion Starter · #12 ·
I'm sure that I read that the rears are the same but that the fronts are differant...but not 100%.
Your correct; I have just checked with Ron Ayers and both the 250 & 400 share same rear wheel bearings :thumbup:
Did you figure out if those were the bearings? If so is that for front or rear?
1 - 13 of 13 Posts
