Hi,
I recently bought a reg/rec from Rugged Roads to my -92 Rd04. The new regulator has eight leads whereas the old only has seven (both has two connectors). The new has an extra black lead in the round connector (five leads). It looks more like the
setup for a Rd07, does anyone know if they at some point had the same regulator? Can I modify the new eight lead regulator to fit the old seven lead?
best regards
Olle
Looking at a wiring diagram for a RDO4 '90 and '91(XRV 750 L & M respectively) only those models had the extra wire (5 lead connector). That extra wire in those 2 models
are a GROUND wire.
Hi,
Thank you for your response! Do you think it would be possible to use the R/R on my -92 and simply leave out the gound wire or perhaps ground it to the frame?
