I've been looking at replacing the standard bars with Renthals on my 650 TA. I've read through loads of posts and the only person who appears to have fitted anything other than the Dakar High (Enduro High 613 bend) is Mudwiz - but that was ages ago.
So, measuring the standard bars to compare with Renthal's listings, I make the specs:
A = 770mm - width
B = 130mm - height at end of bar
C = 115mm - rise
D = 170mm - clamp area width
E = 104mm - sweep
Renthal Applications List here: B&C Express | Handlebar Dimensions - Handlebars
The Enduro High has a lower rise and a slightly lower height than standard but is slightly wider. The bars Mudwiz used were apparently playbike bars. There are currently two listed, 50cc Playbike bars (797 bend) and 110cc Playbike bars (611 bend).
Both of these are higher and with less sweep than standard. The closest to standard, if I'm measuring the bars right, seem to be the 677 bend Suzuki Quadracer.
Now, I don't want anything considerably lower than standard and I don't want to foul anything on full lock so, before I start experimenting, anyone fitted anything else recently?
A = 770mm - width
C = 115mm - rise
E = 104mm - sweep
