For the Pyrenees trip I needed to install a roadbook holder
Due to the cost of the electrickery ones I opted for a manual one
They supplied a mount that the scroller ran through that was meant to be fitted direct to the handlebar. This would mean removing the switchgear so I made up a faux bar made from a piece of handlebar and mounted this to the clutch body with a 22mm stainless P-Clip where the old handguard used to bolt to. Then I fitted the mount and then the scroller. I replaced the harder high pressure airhose link pipe supplied with a softer high pressure airhose
The bodge meant I could retain all the switchgear and scroll whilst still holding onto the handlebar - job done
Inside looking out view
Outside view
Top view
It's almost identical - the one I used was from Raid Designs at 1/3rd of the price of the Acerbis one - great people to deal with - I think you posted up on these a while ago - thanks for that
See it in use here
http://www.xrv.org.uk/forums/ride-reports-pictures/81163-pyrenees-aragon-navarra-2012-a.html
Mine cost me about £2.00 a food container, drilled 4 holes in the side put some electrical conduit through it and drill 4 holes in the back so i could either cable tie it to the handlebar bridge or use a spare ram mount bracket that i had
Yes, that's the one. I think I have a write up on how to make it electrical driven using a small electrical position motor taken from an Audi, and some LED lights för those night missions.
Home made RB's are always good fun, but this Acerbis copy is very nice considering the price.
I would be very interested in that info - would it be possible to email it to me at
paul dot stanley @ landg dot com
Paul
I'll see if I can find it 4 You.
This is what it looks like when modded.
fraggel.se • Visa tråd - Biltema Roadbookhållare
The builder of the unit above used a small electrical position motor from an Audi A4 with part number BOSCH 0132801302.
An additional aluminium plate is also installed, and they exchanged the plastic shafts for ones made of alu.
One of the shafts is directly connected to the motor. You can only drive it forward with the motor. You have to rewind/reverse the notes manually. Some LED's is glued inside the Roadbook holder for night driving.
I'll see if I can find the building instructions for You.
Discussion Starter · #8 ·
Thanks Kjell
