I wondered if anyone knows what the loose part was that I found when removing the plastic front sprocket cover please? It looks a bit like a battery earth metal strap. The cover has the metal part behind to stop the chain eating the casing if it slaps or comes off but whats the seperate small bent metal bit please? Not a good description but if you take the cover off there are two parts?
WHich model do you have, please?
Thanks for the reply I worked it out.... It was the bottom clip that protects the cables as I made the error of removing the cover and 2 extra casing bolts which the bottom one held the clip. (Africa Twin RD07A)
Administrator
Ah... easily done. Glad you're sorted :thumbup:
