1 - 2 of 2 Posts
I have a 97 RD07, and dropped it at the weekend going up a very slippy bridal path . the only damage I did to it was when I picked it up (took an hour) I got it high enough to jam my knee under the side panel while I got a fresh grip. When I eventually got it upright the side panel was flopping about. Once back in my garage I took the side panel off and found that the two mounting bolt holes had completely disintigrated. I took off the other panel and found that it's holes were also on the verge of collapse, and were only held together by the rubber washer. I have spent the last few nights rebuilding these holes using large washers and a two pack plastic steel compound (RB steel very good stuff) to hold them in place.
Has anyone else found a problem with these mounting holes? and if so what remedy have you used?
1 - 2 of 2 Posts
