slight movement in handle bars is this normal its as though there moveing slightly when force is put on.
on my fx650 comeing from sports bike where there fixed I'm unsure
The handlebar mounts on the dominator are rubber mounted where they go through the top yolk might be the same on the fX
Stone Crazy
yes thats correct they are rubber mounted , so they have a bit of movement , it stops to much vibration coming through to your hands that can cause whitefinger disease
Even more noticeable if you have bar risers fitted. ( I once had an old Volkswagen with a couple of inches play at the wheel ,as a teenager it didn't bother me in the slightest !) Thank heavens they do proper MOT's these days. It's something a tester may pull you up on, just explain the rubber as they are not all aware of this and it purpose. :)
