96 xr 400 has developed a small oil leak.im pretty sure its coming from the oil seal around the gear lever, however i was wondering if there is also a seal behind the front sproket.any help would be appreciated.cheers lee.
There is a seal on the output shaft behind the sprocket but the gear shift seal is the most common one to leak.
