Can't find the testing ohms values for the coil, in the handbook, anyone know them ?
Thanks, Wiz
My manual (Section7) details it in terms of Voltage:
Ignition coil primary peak voltage 100 V minimum
Ignition pulse generator peak voltage 0.7 V minimum
Yes, I got that, but not ohms (resistance), I found elsewhere that between 3 & 5 ohms on the primary & +10k ohms on the secondary, should be OK.
Thanks, Wiz.
