Apologies for this one, it's probably really simple.
Under front braking my RD04 seems really snatchy at low speeds, possibly its just not as noticeable at higher speeds. It's sorta intermittent, and if stopped, when I pump the lever there seems to be varying amounts of resistance.
I'm a bit clueless when it comes to brakes, so any theories are appreciated, the disks don't look warped BTW. I'm thinking maybe the brake fluid needs replacing, as I'm pretty sure it was a fairly cursory service it received when it was sold to me by the dealer.
Would heavier Fork oil help with the braking? I also feel like it's a bit twitchy on the front end, particularly on tram-line style tracks. Is there a desirable aftermarket setup to improve the front suspension?
Answers on a stamped, self addressed postcard to the usual address.
Thanking you in advance for your time and trouble.
