1 - 14 of 14 Posts
I will wash it I promise!
some little gits tried to steal my bike recently! they damaged the ignition barrell so i replaced it and bits of other wiring they had damaged!
i lobbed out all the old bits and was very proud of myself!
until today when i got to the petrol station and realised I have thrown out the key to the petrol cap!
any ideas folks?
other than any suggestions involving me being a pillock - i know that much!!
cheers all
Z
I managed to pick mine using a paperclip on one of my RD03's, try that with a thin bladed screwdriver:(
Probably easiest just to buy a new petrol cap with key
(now spot the flaw in my plan
Sorry Z, I know this won't help but......
(wheres the smiley banging another smilie over the head with a BFO hammer when you need one!)
Phil
Discussion Starter · #8 ·
as I don't have the key any more I was thinking of simply drilling out the old lock and then in due course buying a new cap and lock when I can find one on fleabay for not many pennies!
I may try the picking it route or the FBH as advocated by the learned members!
see, this is why I shouldn't be trusted to do anything mechanical at all EVER!!!
d'oh
D
d'oh
D
Lovingly serviced, tweaked & fiddled with, taking endless hours of blood, sweat & tears over the winter months.
Rendered useless by an oversight of its owner :p
Hope you get sorted soon Z
Phil
Sent from my HTC Desire S using Tapatalk 2
Captain unsensible.......
I'd definitely go for the locksmith. Drill + petrol tank doesn't seem like a good mix to me....
Sssssshhhhhhh...... We were just seeing how gulible he was.....
Discussion Starter · #12 ·
ok if this happens to anyone else - here is the procedure!
first prise the plastic cover off the petrol cap (medium force and work around the cap)
second, prise the metal cover of (gently! it has a lip that clips under the cap) use a screwdriver and work around - once this is removed you will have access to the lock
you can then pop the lock out!
assembly is the reverse of disassembly!
simples
and not a hammer used! - kinda!
:blob8:
Can you now re-key the lock to the new key?
Discussion Starter · #14 ·
I reckon I could if I could get a lock to fit that key - from the outside the cap looks the same and looks locked so I reckon not too much hassles - have also now started parking under a CCTV camera!!
Z
1 - 14 of 14 Posts
