it's about an hour......
Images are not showing.
My speedo has stopped working on a couple of occasions. For me it was simply bending the flaps on the speedo bit that goes into the wheel back out a bit. Maybe worth a try. Then before you tighten your wheel back up, just spin it and see if its made any difference on the speedo.
Was thinking about doing that, but is the worm gear worn as ive never seen it before? if it is, then im just gonna order a new one from weemoto today.
Can't see the pics, but I recall having a similar problem with my Honda 550-4 about 20 years ago. There were 2x sets of angled rubber flaps in the drive unit which acted like a clutch - gripping when moving forward and slipping when moving backward. They were in such bad condition I ended up adding a thin layer of Araldite to the surface of the inner race e so that it gripped the outer. Obviously it wouldn't disengage when the bike was rolled backwards, but that's hardly a problem? Self-amalgamating rubber tape would have done a better job I suppose...
Joe
Ride the Sumo!
You can try to make the metal tags the protrude a bit more proud with the use of a pair of pliers or you need a new drive.
Cheers futter,
Just gone and done that now- all seems to be ok, just about to go for test run now, let you know how it goes.....fingers crossed
