So a while back one morning she failed to start, ignition dead.
I traced this to the starter relay, and it was fairly well melted as is well documented - a bit of a wiggle and she came to life.
So I ordered the new relay, which came - and now Ive fitted it I've run into issues and she wont start.
I get ignition lights on, everything else works except the starter.
I can by pass the relay and she turns over, and I can put direct power/earth to relay switching side (two rear) and it works and turns over.
I'll be buggered if I can get the switch to work now.
I've run a meter over the cable that runs to the switch and If I connect the multi to power, then run the earth side to the yellow cable and press the button I see nearly 12v.
Does anyone know how this is supposed to work and how the relay gets power to trigger?
Clutch switch seems to do nothing so I'm at a loss at the moment.
Any help appreciated!
