1 - 1 of 1 Posts
I pulled apart my XR because it was smoking bad and just running bad.... this is my 1st rebuild. I found that the center ring that holds the camshaft was damaged.... for some reason the cam shaft is damaged where it rides in the ring and the ring on the head cover and cylinder head is damaged on both sides... I was able to grind the areas smooth and so I'm thinking about just getting a new cam shaft. Also the knobs on the cam shaft were worn quite a bit and the rocker arms were seriously pitted where they touch the cam shaft, so I have to replace those.... I'm just looking for some advice on where I can get these parts affordably, and is it not wise for me to re use the cylinder head and head cover if they had a little damage. They seemed to clean up pretty good. thank you
1 - 1 of 1 Posts
