Hello friends,
just been arrived from a 3200kms trip arround pyrenees. When I got home after 800kms with arround 36degrees, my battery went almost flat.
Ive been following the electrical fault-find pdf and the stator at 2500-3000rpm, two phases give me 55volts AC and one 75AC...
Also, when I start the engine at idle and connect the multimeter to the battery its gives me arround 14volts wich seems ok..., the worst is when I turn the headlights on and it drops to 12,8v -12,5v...
Whats your opinion? Stator replacement ?
thanks
Just found it was the isolation that had melted..., I had ground connection from the yellow cables to the (-)
cheers
