Has anyone here replaced their steering head bearings? If so...how did you remove the bearing 'race' that is on the lower yoke? This thing...
The internet suggests
- using a chisel
- using an angle grinder
- using a dremel
- using two screwdrivers
- using some sort of special tool
so...how did you do it (if it's stuck on pretty tight)
(The bike is a Transalp 650, but the principal/technique is the same for most bikes)
- using a chisel
- using a dremel
