1 - 12 of 12 Posts
Has anyone here replaced their steering head bearings? If so...how did you remove the bearing 'race' that is on the lower yoke? This thing...
The internet suggests
- using a chisel
- using an angle grinder
- using a dremel
- using two screwdrivers
- using some sort of special tool
so...how did you do it (if it's stuck on pretty tight)
(The bike is a Transalp 650, but the principal/technique is the same for most bikes)
this job is turning into a right pain in the arse
another question. there doesn't seem to be anyway to "knock" the headstock races out. there is no "lip". there is a seamless join between the race and the headstock.
how am i supposed to get them out? cut them using a dremel?
the red arrows indicate the "join" between the (black) frame headstock and the (silver) race
i have the same problem with the race at the top end of the headstock too
any ideas?
Did mine a few months ago I did them as follows
For the stem I used a cutting disc on a grinder and cut it at 45 degrees on opposite sides being careful not to go all the way through, then heated with a gas blow torch the hit it with a cold chisel, make sure you wear safety glasses as it shatters into pieces
For the ones in the head stock I used a long screw driver and give them a good old whack working my way around the edge to get them out in line it takes some doing but they will come out
For re fitting I put the stem ones in the freezer and the pretty much slid in, make sure you give the stock tube a good clean and remove any rust, a small bit of light grease helps
For the one on the stem tube I put the stem in the freezer and the bush in the oven, they again pretty much slid on
Not an easy job but you can do it with a bit of time and patience
Good luck
ok thanks. i am wary of hitting the headstock with anything in case it gets damaged and the new race doesn't sit correctly
The most foolproof way of removing an outer bearing race when you cannot get behind it is with a welder. I have removed hundreds by running a weld bead around the roller or ball track and letting it cool down. When the weld cools it contracts causing the race to shrink. In most cases the race falls out of its housing on its own. In really stubborn cases I may have to weld a bit of scrap metal across the race to punch it out.
sounds good., but i don't have a welder, and i don't know how to weld
all i have is a soldering iron, which isn't much use
If you can get the bike / parts across to West Yorkshire I have a fabrication workshop where I will be able to remove, re fit etc any bearings you may need.
Hi there,
I have done this job twice, for both my bikes.
First, have a look at the video on YouTube from Del Boy's garage on the topic. Very well made.
He uses a set of screwdrivers starting from a small one to create the gap. That is the theory.
The first time I could not do it, I brought to my mechanic the stem and he told me he did not use any fancy tool but heat to sort out.
So, the second time I used the procedure above, with the addition of a Blow torch to keep the area hot.
It worked.
GC
1 - 12 of 12 Posts
