bike nut
well have changed the head bearings on my Vara1000 couple weeks ago, all went well, tightend them up, 'jobs a good'un' as they say
well they have started working loose, i can feel a slight play in the bars when going over pot holes etc.
now what is the best way to prevent them coming loose in the future? Would thread-lock be ok to use ??!!!??
any input would be great! :grin:
thanks
How much is the fish?
From what I´ve read they do settle a little after you change them. It´s recommended to check/tighten them again after 500ish miles.
Don´t use threadlock!
thanks
they do need to bed in just make sure you've tightened the stem nut up properly after you've adjusted them
Hi,
I had the same problem on my old VFR800 so I took the bike to a mate of mine and he just loosened the top nut and top triple clamp lifted the top clamp up ever so slightly then chapped the castellated nut round with a round punch till he got the free play removed from the bearing/stem unit then tightened all of them back up to the correct torque. Took him all of 15 minutes but he did say they can sometimes need two or more repetitions to get them properly settled.
Ian.
