Hi all.
Stripped and cleaned my carb and thought I’d check the jet sizes etc.
On the slow jet was the number 55. Which I understand is quite large!
However I cannot find any size on the main jet only the letters CBT ????
Is that just a model fitment number or do these letters correlate to a size?
There is no numbering on the main jet at all !
CBT sounds like a reference to the Needle that fits inside the emulsion tube, Did you separate the jet from the emulsion tube to clean it?
The needle code is C is the Jet taper, B is the length and T is the diameter of the needle, possibly its a matched set with the needle, do you have the needle code as well?
Will have another look later today, thanks.
