Pannier Rails, Bad Batch
Gregger
I hate to say this, but some of the guys on the site will confirm I sell the SW Motech range and have fitted it to quite a few guys bikes, have a look at the other thread further down from Blues'n'Twos as an example
You should not have required any grinding out what so ever. Did you speak to the people you got them from at all before you did.?
I can advise you that there have been a Bad Batch of frames kicking about, I've had three sets through here in the last month. The root cause being, SW Motech did some mods back in 2004 to rectify these problems, however their stock control system fell down and they had a batch left in the the back of the warehouse of the old frames (it only effects the right hand one) however the rear upper right locating arm is both too short and not correctly situated, causing this problem.
After much investigation and perseverance on my part I was able to prove to them that the right hand frame is actually lower by about 1-1.5cm than the left hand frame. By taking pictures and and measurements. By the way I have a Remus on mine as well and the original set I had didn't have this problem. Londonbubble has now got that set somewhere in Europe on his mega trip.
Put your bike on the centre stand and take off both of your panniers, then look from the rear, if I am right it is quite apparent.
Now the good news. As I have said I have had SW Motech in Germany admit that they have had this faulty batch. You should be able to go back to were you got them from explain to them the problem say you had to mod as you were mounting the luggage for trip you were booked on the very next day so it had to be done or else. They will get hold of the UK importer who I know very well. They will throw up their hands in frustration but should sort out the problem via your dealer.
There is a long lead time for the replacements though, it is in the region of 5-8 weeks whilst they go back and check all their jugs etc and make sure they are manufacturing them to the correct standard. By the way I'm at the front of the queue, so you dealer may have slight wait.
In summary, I have sold thousands of pounds worth of SW Motech kit now and this is the only problem I have encountered with them, as a rule, it is excellent quality at the right price and slots into place with an issue.
If you need any more help getting this sorted you are free to give me a call, you can get all my details at
www.eibcltd.co.uk
