Hi all,
First time twirling the spanners on my V8 a few days ago to replace the air filter with a K&N and chase a niggling leccy fault (fan kept blowing the 20A fuse), I came to reinstall the tank and found a 'spare' vent hose :)
It tees into the thin tank vent hose half way down it's run to the bellypan and just appears to vent to atmosphere too. A quick look on the parts fiche shows no connection to anywhere either.
So, as a new Varadero owner... is yours like this too?
Cheers.
Just a guess, not a definitive answer: A problem that can crop up is that the breather can become blocked and the pump is so strong it can literally cause the tank to collapse. I wonder if the two vents are designed to reduce the likelihood of this? :confused:
It's my thinking too that it's belt and braces. :)
On all my enduro race bikes I used to tee the carb vents off and run an extra set into the airbox, in case the bottom ones got clogged with mud / water.
I just found it strange of Honda to leave it just flopping about with no nice clamp, filter, fitting or wotnot. Has someone from Suzuki been helping them design stuff? :D
