Well, I disconnected everything, drained the oil/coolant etc etc etc
My new best mate Joe arrived and we set to sorting the engine mounts etc.
It all went quite smoothly and the engine left the frame without any skinned knuckles. Got the new engine ready, did the valves, they were pretty much ok but a couple needed adjusting. Used some 8mm rod to make a new stud (wound it right in). One hiccup, the single bolt that holds the chrome pipe coming out of the new engine sheared off I changed that over, water pump as well as my original was in better nick but other than that no dramas.
The new engine went in easier than the old one came out. Very surprised. People can do it on their own but it is dead easy with two of you.
By this time, light was failing so as it stands in the shed I need to refit the rads/coolant pipes, carbs and bodywork. All electrics are reconnected, and lastly I need to refill oil and fit new filter. Both coolant and oil will be dropped in 500 miles or so and all checked again.
Not too hard and Haynes is a god-send.:blob::thumbup::toothy3:
