1 - 11 of 11 Posts
Hello chaps
first of all id like to say hi as im new on this forum and also new to the dommi
im picking up a 96 dommi this weekend that likes to smoke somewhat .
apparently when you start it it smokes heavily but the clears after a few seconds to a slight smoke.
im think this is probably the valve seals and this is what im going to attempt to do ..
is there anywhere on here or another site that has a step by step proceedure for doing this with pics
any help would be appreciated
Regards
Zippy:thumb:
Senior Member
Welcome :thumb:
I would invest in a Haynes manual first of all.
If taking head off to do valve stem seals i presume you intend to lap the valves in while your at it. I would also slip the barrel off and check / renew the piston rings.
Welcome :thumb:
can you get a haynes manual for the nx650 i couldnt find it on their site?
also, Ive never stripped a 4 stroke before so i was looking for a guide for dummies :(
surely it cant be that hard a task as its only a single cylinder right ?
or should i be talking to a mechanic ...id rather learn than pay!
Senior Member
Surprised they don't do one for the Dommie. :confused: The same engine is in the SLR / Vigor etc.
I have one for my XR600 which is basically the same engine.
Contact David Silver's or Ling's for a honda workshop manual, i know they do photo copies of originals for most bikes.
These engines are simple and easy to work on, so you should be ok. . . . Just take plenty of piccies as you go for reference.
There's a genuine Dominator manual available on ebay cheap. Different model but the engines the same.
I'd also sort the bore/rings while apart.
i was going to replace the rings as a precaution but the bike has only done 14000 miles so i wouldnt have thought that it need a rebore unless something really stands out
but arent these engine usually bomb proof im hoping not to find any disasters lol
Senior Member
Good engines depend on good servicing. . . . . . let any RFVC engine run low on oil and the top end will be first to go.
Workshop manual on CD ; Honda NX650 Dominator Workshop Manual NX 650 on eBay (end time 08-Apr-10 23:19:04 BST)
Romanian Trailbiker
You can do with a 1988-2003 Dominator repair manual.
You're going to have problems taking the top off with the engine in the frame.
Mileage is irrelevant on dommies. Around here, every second hand bike sells with 30k km on board. I've seen them with true km or closer to 130k km. Most run pretty well so they get away even with fake mileage. The most extreme was one with 21k km and a piston re-bore (down to the 2nd mark), non-honda clutch, thinned out non-oem brake disks and cluncky top.
Sounds like my SLR, only done 15k kms, but standing for too long betwwen rides. Stripped the top, almost no wear on the bores, valve seats A1, but the valve guide oil seals had hardened a little; enough to make it burn oil like a 2-stroke!
You may be as lucky as me.:thumbright:
Discussion Starter #11
yeah im hoping this is the case but im prepped for the worst now having bought a complete gasket set and manual for an XR650
im collecting the bike this saturday so well know on sunday !!:confused:
1 - 11 of 11 Posts
