G
Changed the oil yesterday but I couldn't manage to get anything other than a ring spanner on the drain plug. Anyone found a way of getting a torque wrench involved?
I'm wondering about trying a 17mm crowsfoot but I don't think a normal one would fit, only a ring type which after a quick surf seem to cost £40 plus which seems a bit excessive.
Spring balance on the end of a spanner??
Forgot to say it's an XRV650
Just tighten it up without putting too much force on it and you will be ok ,
It's not a critical component, just be sensible about it:thumbup:
yeah its a bugger,
I always tighten it with the first two fingers on the lower side palm down and when it hurts too much to carry on its tight enough
I have tested it with a torque wrench and it works out about 20-25NM depending on how brave I feel on the day :D
G
Thanks guys. Just did it up carefully as you suggest, but as getting at it required removing the crash bars and the engine guard thingy I was keen for it not to leak.
Also, I'm a self-confessed engineering detail geek so like the idea of torque setting things!
I usually tighten mine with a socket on a normal 3/8 ratchet. As you say, I can't get a torque wrench in there. I find that the shortness of the ratchet (Halfords professional I think) gives me less leverage than a 17mm spanner, so I put all my scrawny might into doing that up and it has been fine this last trillion oil changes.
I only use torque wrenches for axle nuts now, just so I know it'll undo again at a later date..
Ok ,I sometimes use a sparkplug washer ,it tightens nicely as you feel the washer compress:thumbup:
