Steve
does anyone know or tell me where i could find the correct torque settings,the ones i need are as follows,the oil filter housing bolts,sump bung bolts(on frame and at the bottem),rear wheel axle,front wheel station,fork yokes and also the two allen key bolts on the head the ones that would be removed to set the tappets also what kind of washer goes with these bolts? a sump type(collaspable) or is there ment to be washers on them?i ask this cos mine do not look right,one has a washer slightly out of place,too big dont know looks as tho someone may have been fiddling over the years,surely these head bolts are crucial to the compression?
Steve
thank you Wicky,i made a mistake about the tappet nut its the two 6mm allen key nuts that are only on the righthand side of the head,any idea what they are?
