1 - 20 of 22 Posts
Hello from Slovenia.
I have transalp, all works well, drive allot of miles, own bike for 5 years.
Yesterdaj i start and run on one cylinder(front). After 5 miles it runs on both, when she run without gas runs only on one. What could be wrong
Please help me.
Thank you and stay healty!
Dejan from Slovenia
Hello!
When last time did you change spark plugs?
I think you should check spark plug caps as well
I had similar on my, guilty was spark plug cap the spark was jump on cylinder...
Wysłane z iPhone za pomocą Tapatalk
Will check and i will tell.
Thank you.
What about catburetor on cdi?
I think spark plugs caps
I had exactly same like you on high revs works both cylinders on low rpm works only one new spark plugs and new spark plugs caps solve the problem
Spark plugs caps looks fine but i took transalp to dark place start engine and than i saw spark jumping from cap to cylinder i’ve got transalp 700 so i have only two spark plugs on cylinder but in yours they are two spark plugs for cylinder
Only idea what i’ve got at the moment is replace all 4 spark plug caps for new one, they are cheap on ebay or at shop, before you will start strip your bike...
Thank you all, now im in my garage and i will start to diagnose what is wrong with her. Will start with spark plugs and i will report to you.
Dejan
Dejan
Discussion Starter #11
I disconect both cables from cylinder and there allot of sparks.
Fire on rear cylinder is only if i came very close to the spark.
Discussion Starter #13
Will go to garage now and i will try.
Tachometer is working, front cylinder is ok.
Why rear sometimes work sometimes not? When i disconect both cables from sparks you can see and hear sparks. And feel too😁.
I newer change, swap or disconect any of cables, except from battery.
And thank you for helping me out.
Dejan
Discussion Starter #14
Ok.
I change ony one spark plug on rear cylinder and now bike runs fine. Is it possible?
Thanx
Dejan
each cylinder has TWO spark plugs
if one spark plug is not working the bike will run but it may appear to only run on one cylinder
you need to check:
the plugs
the plug caps
the leads to the plugs
all wires to the CDI "black box" (underneath left hand side panel)
the fuel supply (ie is it reaching both cylinders ok?)
Ok.
Thanx
Dejan
It is possible like i’ve said buy new one spark plugs all 4 and plug caps its not cost of fortune but should help
Discussion Starter #17
Running on one cylinder, over 2000rpm runs on both.
What is wrong with her?????😞😞
It sounds an odd one & nothing obvious comes to mind
Has it been laid up overt the winter? If so was it prepped, carbs drained? When was it last used? Mieage?
Discussion Starter #20
All sort!
Rust from a tank plugged on of the yets.
I open carbs and it was full of brown like a fine sand.
Now she runs like a champ!
Thank you.
1 - 20 of 22 Posts
