1 - 1 of 1 Posts
bike nut
I have sold my trusty Alp and have a whole bunch of spares I am offering here as a job lot before they go onto the Fleabay
So here we go
-JT chain a sprocket kit, 118 X-Ring chain, 47 rear, 15 front
-JT 15t front sprocket
-brake lever and clutch lever in black
- 44806-KFO-000 Speedo drive plastic pick up
-2 x Fuel filter
-3 x DPR8EA9 spark plugs
-2 aftermarket brake pins and caps
-17258-MF5-000 Airbox to Carb rubber boat
-Genuine clutch cable
-Rear shock raising clevis
-Used set of airbox to carb boots (both of them)
-Carb to engine rubber used
-All balls rear linkage bearing kit with couple of genuine seals
-Used regulator/rectifier
-Rear dogbone and side plates
-Exhaust gaskets x 2
-2 x Genuine front wheel bearings and 1 seal
-Full clutch basket assembly without the plates
-2 used CDIs in original rubber holder
-Starter motor
-1 Brand new CDI
£150 for the whole lot
Located in Sheffield if you want to collect or delivery can be arranged for an extra £20
1 - 1 of 1 Posts
