Captain unsensible.......
Just replacing the clutch plates on my transalp - i have both the metal and cork plates but one of the cork type clutch plates has a different part number than the rest - does this plate sit on the outside of the plates?? I've destroyed my manual so cant check
Ta sean
Ta sean
From the fiche of the clutch you appear to be correct -
Plain plates (No 8) are 22321-MN8-000.
Friction plates (No 6) are 22201-MCB-610.
The odd plate (No 7) is 22202-MAE-000, called "Disk B, Clutch Friction" by Honda.
Hope that helps.
Tony
Administrator
The "odd" plte and the two rings should be assembled thus...
I assume the rings works as a sort of sprung plate-separator,or perhaps "cushion".
