1 - 2 of 2 Posts
Administrator
Transalp XL600 Engine Restriction Details for production years 1991 - 1999
There appear to be changes to the carburettor jetting on restricted models. I'll post up these details when I've worked out what they are.
This page hopes to detail which XL600V Transalp engines were restricted and also how they were restricted.
There were a number of changes from year to year, so I will present the information for each year of production and provide as much detail as available to me.
Also, the Honda Area (Market) Codes are my best guess. Again, if you know better then let me know.
Production year 1991 - XL600V-M, 1992 - XL600V-N and 1993 - XL600V-P.
Full Power models for markets AR (Austria), E (England), F/YB (France), FI (Finland), G (German), IT (Italy) and SP (Spain).
Restricted models for Germany (G/27P) and Switzerland (SW).
All models have the same CDI units, the changes were to the Inlet Rubbers and Cam-shafts.
Standard Inlet Rubbers, Part No: 16211-MM9-000
Standard Cam-shafts, Part Nos Front: 14110-MS8-000 and Rear: 14120-MS8-000
Restricted models.
Market - Germany (Honda Area Code "G/27P")
Restriction indicated by change in engine number from full power models.
Engine Nos: PD06E-3400001 to 3400952 for 1991,
Engine Nos: PD06E-3500001 to 3501067 for 1992 and
Engine Nos: PD06E-3600001 to 3600700 for 1993.
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16211-MS6-710
Market - Switzerland (Honda Area Code "SW")
Engine Nos: PD06E-2400022 to 2406989 for 1991,
Engine Nos: PD06E-2501544 to 2508309 for 1992 and
Engine Nos: PD06E-2603303 to 2608382 for 1993.
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16211-MS6-930
Cam-shafts, Part Nos Front: 14110-KW0-000 and Rear: 14120-KW0-000
Since there are not unique engine numbers for this market the only way to determine restriction is to check the part numbers. For the camshafts this means a top-end inspection.
Production year 1994 - XL600V-R.
Full Power models for markets E (England), F (France), G (German), IT (Italy) and SP (Spain).
Restricted models for Austria (AR), Germany (G/27P), Italy (IT) and Switzerland (SW).
Standard Inlet Rubbers, Part No: 16211-MS8-000
Standard CDI Unit, Part No: 30410-MS8-610
Restricted models.
Market - Austria (Honda Area Code "AR")
Restriction is by change of Inlet Rubbers. Unique engine numbers for Austrian market.
Engine Nos: PD06E-5700003 to 5700716
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16210-MAB-690
Engine Nos: PD06E-6000001 to 6001425
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16210-MS6-830
Market - Italy (Honda Area Code "IT/34P")
Engine Nos: PD06E-2700001 to 2712050
Because there are no unique engine numbers the only way to determine restriction is to check the part numbers of the Inlet Rubbers.
Restriction is by change of Inlet Rubbers and Cam-shafts.
Engine Nos: PD06E-2700004 to 2712247
Because there are no unique engine numbers the only way to determine restriction is to check the part numbers. For the Cam-shafts this will mean a top-end inspection.
Production year 1996 - XL600V-T.
Restricted models for Austria (AR), Germany (G/27P), Italy (IT/34P) and Switzerland (SW).
Restrictions by CDI Unit, Inlet Rubbers and Cam-shafts depending on market.
Standard Inlet Rubbers, Part No: 16211-MAW-600
Standard CDI Unit, Part No: 30410-MAW-620
Restricted models.
Restriction is by change of Inlet Rubbers and CDI Unit. Unique engine numbers for Austrian market.
Engine Nos: PD06E-5800001 to 5800552
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16210-MAW-690
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16210-MAW-710
Inlet Rubbers (called "Insulator, Carburetor" by Honda): 16210-MAW-740
Restriction is by change of Inlet Rubbers, CDI Unit and Cam-shafts.
Production year 1997 - XL600V-V.
Full Power models for markets Austria (AR), E (England), F (France), G (German) and IT (Italy).
Restricted models for Germany (G/27P), Italy (IT/34P) and Switzerland (SW).
Standard CDI Unit, Part No: 30410-MAW-621
Restricted models.
Engine Nos: PD06E-6200001 to 6299999
Engine Nos: PD06E-2900001 to 2999999
Restriction is by change of CDI Unit.
CDI Unit, Part No: 30410-MAW-771
Production year 1998 - XL600V-W.
Restricted models for France (F/34P), Germany (G/34P), Italy (IT/34P) and Switzerland (SW).
Restricted models.
Market - France (Honda Area Code "F/34P")
Engine Nos: PD06E-6300001 to 6399999
Market - Germany (Honda Area Code "G/34P")
Engine Nos: PD06E-8000001 to 8099999
There are apparently unique engine numbers for Italian market restricted models, which is a bit odd since the only change between the models is the change to the Inlet Rubbers.
Engine Nos: PD06E-4000001 to 4099999
Production year 1999 - XL600V-X.
Restricted models.
Engine Nos: PD06E-6400001 onwards.
Engine Nos: PD06E-8100001 onwards.
Engine Nos: PD06E-4100001 onwards.
Thank you for this!
Am I correct to assume that on my 1996 German XL600vt 34hp I only have to change the:
To get full power?
1 - 2 of 2 Posts
