1 - 1 of 1 Posts
SOLD
Okay, it's a tough decision as I love my Transalp and she's NEVER let me down but I want an Africa Twin and as I can't afford two bikes then she has to go!
So for sale is my trusty Honda Transalp.
This has been my trusty commuter to work and has NEVER let me down. The only time I've had to call out the RAC was when I messed up and ran out of fuel miles from home! This includes a trip to France and Spain through the Pyrenees where it never missed a beat on any of the cols and mountain climbs. I'm only selling as I fancy a change of bikes.
It's currently done 63720 miles but until sold I will still be using it to commute to work on.
It comes with two ignition keys, Honda topbox with 2 keys and heated grips. It's fitted with Michelin Anakee tyres still with lots of wear in them. It is also currently fitted with Touratech crash bars and Touratech pannier rack and 2x38l Touratech panniers ... I can sell these with the bike if required for £300 otherwise I will remove them to sell seperately.
The bike is also fitted with a Fuel exhaust instead of the original. I've rode this bike in all weathers and despite being thoroughly cleaned regularly there are signs of corrosion. This is as to be expected for a bike of this age and mileage. The only other thing that I know is wrong with the bike is that the fuel gauge does not work. This is not an issue as I just reset the trip every time I refuel. The bike does 180 miles on a full tank so I just refill at 170.
The bike is a great runner and I commute and tour daily at motorway speeds without any issue. I don't do off road as it doesn't have the tyres for it and I don't have the skills!
The full specs are as follows:
DIMENSIONS
Overall length 2255 mm / 88,8 in
Overall width 905 mm / 35,6 in
Overall height 1305 mm / 51,4 in
Wheelbase 1515 mm / 59,6 in
Ground clearance 182 mm / 7,2 in
Seat height 837 mm / 33,0 in
Curb (wet) weight 219 kg / 483 lbs - Honda Transalp 700 (ABS)
FRAME
Type Semi-double cradle (steel)
Front suspension, travel 41 mm telescopic fork, 177 mm (7,0 in)
Rear suspension, travel Swingarm (Pro-Link) with mono-shock, 173 mm (6,8 in)
Adjustable: spring pre-load, rebound damping
Front tire size 100/90-19M/C (57H)
Rear tire size 130/80R-17M/C (65H)
Front brake Double disc, 256 mm, 3-piston caliper (XL700VA – C-ABS)
Rear brake Single disc, 240 mm, 1-piston caliper (XL700VA – C-ABS)
Fuel capacity 17,0 l / 4,5 US gal (including 3,0 l - reserve)
Trail 105.5 mm (4,15 in)
Fuel economy 4,7 l / 100 km
ENGINE
Type Water cooled 4-stroke
Cylinder arrangement 2 cylinders 52°, V-twin
Bore & Stroke 81,0 x 66,0 mm (3,19 x 2,60 in)
Displacement 680 cm³ (41,5 cu in)
Compression ratio 10.0:1
Valve train Chain driven SOHC, 4 valves per cylinder
Max. power 60,0 hp (44,1 kW) / 7750 rpm
Max. torque 60 Nm (6,1 kg*m) / 5500 rpm
0 to 100 km/h 5,1 sec
Top speed 172 km/h (107 mph)
CARBURETION SYSTEM
Type Fuel injection: PGM-Fi, 40 mm
DRIVE TRAIN
Clutch Wet, multi-plate
Transmission 5-speed
Final drive Chain
Primary reduction 1.763
Final reduction 3.133
ELECTRICAL
Ignition Full transistorized
Alternator 396W at 5000 rpm
Battery capacity 12V-11.2 Ah
SOLD
1 - 1 of 1 Posts
