1 - 1 of 1 Posts
Hi there
Has anyone had similar troubles with the AQ fuel tap?
First it looks like the pilot light lives it's own live: it could lit up unexpectedly (even with the full tank), light for several minutes and then get off. This could occur many times during the ride regardless of the fuel amount in the tank. I've installed the tap last year and this behaviour persists all the season. Didn't had the time to to check the setup till this days. I will try to check the tap with multimeter to see if it works correctly. Any thoughts on other reasons why this occurs?
Also the tap blocks the fuel flow in the "reserve" position and permits in "off" position. It looks like the lever is mounted incorrectly, so maybe is it possible to reposition it? I can live with it if it can not be fixed but it's better to check it out;)
1 - 1 of 1 Posts
