Just fitting new tyres on my new to me RD04.
I have gone for Tourances, they seem to have a good rep and in my current financial state are cheap.
Fitting them? I have a local shop ho do it for a tenner the pair, lucky old me.
Question.
Both wheels have those bolt on thingies that clamp the tyre to the rim. Are they neccessary? I remember them being a pain on my old Tenere in Ghana, but did enable me to ride 150 miles on a flat tyre in an emergency.
There is a horrible high speed vibratio, at around 80/85mph that I think is due to front wheel balance and I wonder if the clamp thingy might be causing this.
The other option is a slightly warped disc, but i figure address one issue at a time.
There is a load of balancing weights on the front rim opposite the clamp thingy. My guess the imbalance is due to this.
My opinion only but mine hasn't got them and no problems so I would say you can take them off and the balance weights then see how it rides
That is my plan.
They are good when riding in sand at low tyre pressures, we have recovery for flat tyres and not many deserts around here.
Aren't Tourance tires tubeless?
BTW I have them on my 1150GSA and they suck on everything but tarmac or packed gravel. Sand and soft ground? Forget about that... :toothy9:
Lee
I wont be doing sand and soft ground, that was referring to the clampy things.
I do some gravel roads when going paragliding but only in the dry.
I started researching tyres again.
It drove me nuts. But they consistently got good reviews and £130 the pair seemed helpful.
I was not sure about tubes in tubeless tyres but the rear on the bike was fine with one.
Lets hope I can sort out the irritating vibration.
if it is not balance weight related it must be a warped disc.
What I like with Metzeler's Tourance is that they get great milleage. They last and last. :D
If you are on a budget and want long lasting tires that will fair quite well on and off road, I suggest checking the Mitas E07. Had them on my RD03 for touring France, Spain, Italy and Tunisia's desert and mountains, and I was impressed. And they are cheap...
