1 - 13 of 13 Posts
A new one today. On the way home, filtering through traffic, found a clear bit and went to shift in second to nip past the queue. Clutched it and found that I couldn't toe the lever up. Gave it a mighty go and after a heavy "chonk", it finally shifted up. CAme up to the light and tried to shift into neutral so I could lean over and have a look. Nothing doing. No neutral to be found. Lever kept chonking up and down between 1st and 2nd with nothing in between. Got home alright though shifting was still a battle. Spent 10 minutes outside the house trying to get it into neutral. Again, no joy.
Any ideas, anyone? It's been fine up to now(apart from a bit salt stiff).
Is it the clutch?
I have this problem when the clutch is too tight.
If it is, it tightened itself. I'll check tomorrow morning.
My AT has always shifted hard(though not as badly as my SuperTenere) but yesterday was unusually rugged. A bit disconcerting as well since it's my only transportation. Taking it in to my meccy to mount my new TKC80'S(woo-hoo!!) but will have a (light)service done as well. I'll have him check it all out. Hate having to pay for simple servicing but I hate taking my bike apart in the street even more(no garage or off-street space).
Wich oil are you using?
Never had that problem with the @, but with an enduro bike, i used a thick oil because i use it in desertic/sandy areas (in order to bear the heat). The neutral was dificult to find sometimes!!! in cold nigths i had to have someone pushing the bike in order to "unglue" (?) the gear plates!!!!
I never had particular problems with the AT's gearbox, although it seems to switch gear more smoothly on some days than on others. It's almost human :wink:
Things like oil (I run cheap-ish but excellent Halford 10W40 mineral for motorcycles), temperature, too much free play on the clutch cable and even a too tight / too loose drive chain seem to have some influence on gear-change and finding neutral.
Alternatively, plan a trip to Switzerland to find neutral.
OK, I'll get me coat now :wink:
Good luck, I hope it is nothing serious.
Discussion Starter · #8 ·
Ah, the ol' Switzerland joke. Some things never go out of fashion :D Running super-duper official Honda-approved 10W40. Going to have a rummage round AT's innards this afternon while there's still light to see if there's somnething obvious. Whenever I have bike trouble, 9 times out of 10 it's something stupid that makes me go "DOH!"
Can you do it whilst moving (like putting it in neutral just before coming to a halt)but have trouble when stopped unless the engine is cut?If so it's just incorrect clutch adjustment .
G
Robster said:
Simon said:
I think thats about my only problem with my @, is that i really struggle to find neutral.
Rev to about 3000rpm with your clutch lever held in and it'll drop into neutral quite easily. I know what you mean though, it can be a right arse.
Must try that next time the bike is on the road. Its supposed to be off the road for the winter but you know what its like. I just love it so much i can't stop riding it. I have come up with the best solution though - send you seat away to G.A. Wells for reworking and then you can't ride it!
So :?: :?: Solved the problem :?:
Discussion Starter · #13 ·
Nope, not yet. Still just as stubborn today. Still no neutral either, moving or at a standstill. Tried adjusting the clutch. The noise it makes when shifting up or down sounds really bad. It's always clunked into gear but this is much worse than usual. I blame all the city driving I do on the way to work. There's no two ways about it. I have to buy a second bike. :D
1 - 13 of 13 Posts
