1 - 2 of 2 Posts
RD07A... Hi guys. I'm putting the bike back together and want to know where the carb breather pipe goes. There is a T piece by the fuel tap that goes from both carbs. The pipe goes down to the bash plate to drain and there is a loose pipe up under where the tank goes. Is this just supposed to be loose or does it attach to something? Cheers
Breathers should just collect together in a bracket near the bottom of the motorcycle. As obviously they allow air in (hence the word breather) They do this as air needs to fill up the space in the fuel tank as it empties.
Same with carbs.
1 - 2 of 2 Posts
