1 - 20 of 60 Posts
Any news yet Pete?
Captain unsensible.......
Take legal advice, then Trading standards, mcn, ride magazine, BMW Germany, and every single forum you can.......
I would see if you can get an independant engineer to see what their view is.....
keep at them though Pete.
SOTGATT
How many Final Drives has it had,
and how many would it normally be expected to have had?
I'm thinking that if there's nothing wrong with the final drives then there's something wrong with the bike and they're just fixing the symptoms each time...thus the fault re-occurs( Sorry if I'm stating the obvious).
I'll pass the info on to my Nephew who is a Trading Standards Officer....see what he thinks.
Have you tried taking it to Buckingham Palace and asking for your money back ?...:hitler:
I thought shaft drives were meant to be cheaper than Chain and Sprockets, as in not needing replacing.
You're thinking of the 1970s and 80s. The 90s and err.... 0ees is a whole different kettle of worms.
Deer Dodger
Sorry Pete,
Really feel for you - honest I do :(
Are you sure that there is not a problem with your alignment - just seems too much that the final drive should fail so many times :(:(
Sorry - I'll do that again ---
Chad -- Do you think that the alignment is out ??
Has the bike been dropped or has had a sideways shunt ??
Just doesn't add up :confused:
Please have a look at the alignment on ZER PANZER :thumbup: before the old duffer cracks up :D:D:D
Surely, in simple terms a final drive consists of;
A shaft with a bevel gear driving another bevel gear and shaft which turns the wheel, supported by a couple of bearings & shimmed up to give the correct backlash/tolerance?
Assuming that out of the 3 or 4 rebuilds, some, if not all must have been done correctly, that only leaves a machining/alignment problem???
What actually happens when the final drive fails - does the rear wheel wobble & lose oil indicating a bearing failure or do you get a course, rough sound indicating gear wear.
Really hope that you get sorted Pete - don't let the B**tards grind ya down.
Phil
Discussion Starter · #9 ·
Phil
From what I understand the first signs are the ABS failure light comes on and the speedo goes erratic due to the ABS sensor getting covered in bits of cack from the failing final drive.
I know it must be a complete pain in the arse. And the wallet. Time for a change of bike I think.
G
When I was a gear shop Inspector at Hawker Siddley Diesels we produced bevel gear sets. The only way to pair them up was to run a couple in a jig and when they were running silently they were matched as a pair.
I know Pete loves his GSA, but I would agree get rid of it and get another bike, there is definitely something wrong with this one.
not this time mate it went pop pretty quick..it would seem that the guilty party is always the smaller roller bearing that gives the problem.
the alignment on petes bike is fine ,,if it was that far out to keep causing these problems it would ride like a pig.
but petes bike rides sweet and tracks true,,,im at a complete loss and await the prognosis of the guy who is doing the rebuild:thumbup:
Wing Commander
I've told Pete this already but I spoke with BMW who took a look at the history they have.
Basically they are saying that it is very unusual for a GS to have four final drives go. They did not know for sure that this time is the final drive as Pete had not then taken the bike to an authorised dealer.
There are a number of concerns they have that, because the bike is not serviced by BMW, they cannot know.
If you ride the bike through water then shortly after you need to replace the oil in the final drive as it can dry out. A full service history would show them that this had been happening. They can't know that with Pete's bike.
Has Pete overloaded it? The Maximum weight is in the owner's guide and the maximum luggage weight is inside the panniers. Overloading might cause the problem. This was blamed for the Long Way round final drive problems - they overloaded the bikes.
Last time, although the bike was out of warranty, the final drive was replaced as a gesture of goodwill by BMW UK. They have all the photos of the old drive etc.
A dealer would still have to see it and make the recommendation. And they wouldn't want to get anyone's hopes up that they'd repair it.
They're basically saying that if it had been serviced by BMW they would be clearer about how the bike had been looked after. They'd be more likely to sympathetic with a full service history. But they'd still be concerned that the bike might be being overloaded or not maintained properly.
That's the official BMW line.
21st Century Schizoid Man
Maan, I know how much you like your bike Pete; this is a very sad story :(
Craigypops
Chris, that just sounds to me like company BS (i know there not your words). BMW basically saying oh you should have paid a fortune for us to service it `properly` then we MIGHT be able to diagnose in more detail but it could be still caused by things out of our control. You just got to laugh, there saying you should always get them serviced by them in case of this kind of thing happening but theres still a few other things they can blame it on so it's still not there fault.
If it goes through water the oil in the drive should be replaced...lmao, i thought this was an adventure bike?, so glad i stuck with the strom, in 17000 miles all ive had to replace is 2 washers in the oil cooler and a clutch slave, total cost, under £30.
Bloody furriner
That's what you get with submerged shaft drives, there's a little air hole on them somewhere. Though it'd have to be some serious wading, not just a splash & dash through a little ford.
(Other things to keep in mind when doing serious fording in dirty water: I think the clutch is out in the open. At least it is on the old airheads, those get wet clutches when doing deep fords. Now imagine muddy water on a dry clutch plate... :rolleyes:)
Vee haf Vays of making you pay.
In search of 7th gear!
Sorry to hear of your final drive woes, really hoped the last time had it sorted! :(
Good luck getting the bike back on the road and I hope this is the last we'll hear of the FD issues!
JB
SHW'MAE BUTT
Found out to day the 1200 gsa can only carry 25 stone the 1150gsa can carry 30 stone.
THis information has really perssed me off and got me worried,as I'am 18 stone naked. with clothing and helmet you could add at least another stone taking it to 19 stone , My 13 year old Daughter is 8 stone with kit 9 stone. So we are overloading the bike already with out panniers and camping gear, Wot a Pisser....
BMW DODGY DIFF CLUB
1 - 20 of 60 Posts
