M
McVicar
·Guest
Introduction
Honda’s class-leading Adventure Touring flagship, the mighty and majestic Varadero, brings a whole wide world of new riding frontiers within easy reach for the most far-ranging blend of motorcycling enjoyment you’ve ever had the pleasure to experience. Powered by a slim, high-performance fuel-injected 1000cc V-twin engine and ruggedly outfitted for long-distance expeditions over virtually any road one might encounter, the Varadero feels just as strong and confident sailing down the motorways as it is exploring less travelled backroads in your search for new adventures. Its broad, windbreaking front fairing, progressive long-travel suspension and comprehensive accommodations for two ensure exceptional riding comfort, and the Varadero’s easily
attached optional luggage system makes longer trips as easy to prepare for as pack, snap on and go.
New for 2004, the Varadero also comes available in a new ABS-equipped version that complements the responsive braking capability of Honda’s famed Dual Combined Brake System with the confident control of the world’s most advanced motorcycle Antilock Brake System for smooth and swiftly effective braking control in virtually any road and riding conditions, and a much-appreciated boost in operating confidence when roads turn nasty.
Colours
• Mute Black Metallic
• Shield Silver Metallic (with Black)
• Pearl Breezy Blue (with Black)
New Features
• New ABS version incorporates same basic features as standard version.
• New ABS version’s system configuration basically same as that featured on the VFRABS.
System uses two ABS modulators, the front one located inside the front cowl and the rear one positioned under the rider’s seat, near the rear damper preload adjuster. Additional equipment includes ABS sensors and Hall effect pulsar rings on the wheels, a new right sidecover design, and a new ABS failure warning light installed in the redesigned instrument panel.
• Rear damper features new adjustable rebound damping (ABS version only).
• Rear damper preload adjustment knob moved from inside of right sidecover to left side. New right sidecover features matte black panel covering previous access hole.
• New arrangement of indicator lights on instrument panel features two sets of four LEDs, replacing two sets of three lights. Low fuel warning light moved up to left-side group from current position inside tachometer dial. All other design features remain the same as the current model.
• New colour variations.
Specifications XL1000V Varadero (ED-type)
Engine
Type Liquid-cooled 4-stroke 8-valve DOHC 90° V-twin
Displacement 996cm3
Bore x Stroke 98 x 66mm
Compression Ratio 9.8 : 1
Max. Power Output 69kW/8,000min-1 (95/1/EC)
Max. Torque 98Nm/6,000min-1 (95/1/EC)
Idling Speed 1,200min-1
Oil Capacity 4.1 litres
Fuel System
Carburation PGM-FI electronic fuel injection
Throttle Bore 42mm
Aircleaner Viscous, cartridge-type paper filter
Fuel Tank Capacity 25 litres (including 4-litre warning light reserve)
Electrical System
Ignition System Computer-controlled digital transistorised with electronic advance
Ignition Timing 10° BTDC (idle) ~ 45° BTDC (4,500min-1)
Sparkplug Type IJR8B9 (NGK)
Starter Electric
Battery Capacity 12V/18AH
ACG Output 434W
Headlights 12V 60W x 2 (low) / 55W x 2 (high)
Drivetrain
Clutch Wet, multiplate with coil springs
Clutch Operation Mechanical; cable-actuated
Transmission Type 6-speed
Primary Reduction 1.682 (44/74)
Gear Ratios 1 2.571 (14/36)
2 1.684 (19/32)
3 1.292 (24/31)
4 1.100 (30/33)
5 0.969 (32/31)
6 0.853 (34/29)
Final Reduction 2.938 (16/47)
Final Drive O-ring sealed chain
Frame
Type Diamond; steel tube
Chassis
Dimensions (LxWxH) 2,295 x 925 x 1,500mm
Wheelbase 1,560mm
Caster Angle 27° 30'
Trail 110mm
Turning Radius 2.58m
Seat Height 838mm
Ground Clearance 181mm
Dry Weight 235kg (*241.5kg)
Kerb Weight 262kg (F: 122kg; R: 140kg); *268.5kg (F: 123kg; R: 141.5kg)
Max. Carrying Capacity 201kg
Loaded Weight 414kg (F: 154kg; R: 260kg); *420.5kg (F: 155kg; R: 265.5kg)
Suspension
Type Front 43mm telescopic fork, 155mm axle travel
Rear Pro-Link damper with 40-step spring preload (*and stepless rebound damping) adjustment, 145mm axle travel
Wheels
Type Hollow-section triple-spoke cast aluminium
Rim Size Front 19M/C x MT2.50
Rear 17M/C x MT4.00
Tyre Size Front 110/80 R19M/C (59H)
Rear 150/70 R17M/C (69H)
Tyre Pressure Front 250kPa
Rear 250kPa (with passenger: 280kPa)
Brakes
Type Front 296 x 4.5mm dual hydraulic disc with Combined 3-piston callipers (*ABS) and sintered metal pads
Rear 256 x 5mm hydraulic disc with Combined 3-piston calliper (*ABS) and sintered metal pads
*XL1000V Varadero ABS
Colours
New Features
Engine
Displacement 996cm3
Fuel System
Throttle Bore 42mm
Electrical System
Starter Electric
ACG Output 434W
Drivetrain
2 1.684 (19/32)
3 1.292 (24/31)
4 1.100 (30/33)
5 0.969 (32/31)
6 0.853 (34/29)
Frame
Chassis
Wheelbase 1,560mm
Trail 110mm
Seat Height 838mm
Suspension
Wheels
Rear 17M/C x MT4.00
Brakes
