Hi,
This is what I wanted from the bike, it might not be for you.
If you are thinking of following the instructions on the thread, then please read them. Do not just skim over quickly & hope for the best, you will be disappointed with everything you do.
This has taken quite a lot of time to get it right, like a recipe, miss one ingredient & it will not work.
There are lots to this modification, you will need:-
VTR carbs,
VTR inlet rubbers,
VTR airbox,
washers for the needles,
Plugs for the pair system,
2 VTR short velocity stacks,
2 Ducati (748,916,996) velocity stacks.
Lots of patience.
Then you have to cut holes in the carburettor mounting plates for the Varadero fuel lines. And shape the VTR Throttle position sensor (TPS) so that it fits into the Varadero TPS plug.
The first step is to install a set of #48 pilot jets. Then you need to shim up the needles. Around .040" is a good starting point but will need to be tuned to each bike. Also there is more to it than just shimming both needles .040". One of the set up tips from HRC is to use one more shim on the rear needle than you use on the front. So what I do when setting up a set of carbs is remove the stock thin washer that is under the front needle and leave it in place on the rear. With this method you actually end up with the front needle approx. .030" higher than stock and the rear .040" higher than stock which seems to work well. The pilot screw set at 2 1\4 turns in the front and 2 1\2 turns rear as a start and the bike will work pretty good.
There is nothing new here, it's all in the thread if you read it.................
Regards.
