1 - 13 of 13 Posts
Hi All.
I have some welding to do on my XR frame, I presume that I have to diconnect the alternator before I do the welding, is there anything else that needs disconnecting as well before I start??
Hi All.
just the earth off the battery mate, no need to disconnect the alternator
Senior Member
Hi All.
Play safe and disconnect alternator, CDI unit and anything else you can unplug. . . . .( only takes a few min's ) . . . . battery is not standard on XR600 but if it's fitted with one disconect and remove.
I presume you will be using MIG or TIG, either way clean paint from an area of the frame to fasten the earth clamp to.
Hi All
Thank you for your replies, yes no battery, I have disconnested the CDI, voltage reg/rect and I think I will do the alternator as well, just to be safe, ark welding it, a friend of mine used to be a pro welder but not worked on bikes.
bike nut
Hi All
what are you welding? did you get the forks changed over? need some pics when your done! :D
Hi Jamie.
Side stand cracked, all done now was quite a job, XR tubing is very thin indeed.
On the USD front, took a long time to find/ get someone to machine the steering stem, but that was done last week, just done a total strip and rebuild of the forks, were going out for a big ride this weekend, so I,m putting them on next week, don't worry after all the works done I will be putting some pictures on the forum.
Hi - I'm not any sort of expert on welding either but been reading a thread on do/don'ts of welding over on TT ... aside from what's mentioned above, the advice is to make sure that you site the earth so that current does not have to go through any bearings. This shouldn't be an issue for you as your welding and (hopefully) earthing on the main frame, but just thought I'd mention it in case ...
Ads
Discussion Starter #11
Hi Jamie.
Went out on Wednesday eve, felt really good, but it was cut short before we got to some hard going as my mate broke his collar bone:(
Have you got your forks level with the top yoke?
bike nut
i have them flush, so the bike is at full stance :thumbup:
how do you find the height? mine seems to be the tallest bike i
have ever owned! :confused::D:thumbup:
1 - 13 of 13 Posts
