Most of Henrietta is now back where it should be and looking tidy. Under the tank is just the fuel pipe to the pump but the parts diagram seems to show other hoses (parts 45, 46 & 48). there seem to be 2 short pipes under the tank (nr the fuel tap), one is 10.5mm and the other 5.5mm. Does anyone know what the 3 hoses are for; 1 i think is the overflow, one is the breather and the other? :confused2: And is the "Y" connector (part 1) important or will just 2 lengths of hose work fine?
One is tank over flow and the other two are carb float bowl over flows.
I can't see why two bits of pipe wouldn't work.
The bigger pipe is the drain around the filler cap stops water building up around the cap and running into the tank when the cap is removed.
  • Like
Reactions: Jayne
