Cant seem to work it out, I have a M reg DR350 first registered in 1995. Its kick start with no battery or anything, it also doesn’t have a crush drive.
Pictures of it can be seen here, in another thread:
http://www.xrv.org.uk/forums/suzuki/36138-just-got-dr350-amazing-bike.html
I ordered some parts for the rear brake off wemoto in the Suzuki DR 350 SER/SES 94-95 section, as i thought thats what model it was and the rear caliper piston doesn’t fit!
So have I got the wrong model, or is something else going on here? Also the old piston which was truly knackard is made from a black composite type material. Where as this new one is stainless steel and at least 2mm more in diameter.
How are wemoto for exchanging parts?
Do you have any cheese?
Is there a option for DR350E, it sounds like you have the enduro model!
Is there no cover on the front sprocket? Does it have a mikuni carb? if yes to both of these, then you have the enduro model!
Just seen your pic on your other post, it is defo the enduro model!
:thumbup:
Thanks DRLANER,
These are the only options listed:
Suzuki DR 350 SET 96
Suzuki DR 350 SEV/SEW 97-98
Suzuki DR 350 SEX/Y 99-00
Suzuki DR 350 SL/SM/SN 91-93
Suzuki DR 350 SP 94
I did think it was the enduro model, but doesn’t seem to be an option for it? Unless its under something other than E?
