BLUE 1999 xrv750x
HI ALL,
IVE BEEN READING THIS THREAD AND GOT THE INFO FOR ORDERING REPLACEMENT BEARINGS.
Front wheel left & right - 6203
Rear wheel right - 6203
Rear wheel left - 6303
Sprocket carrier - 6204
Bearings with the suffix "2RS" are rubber sealed both sides.
ARE THESE CODES THE SAME FOR THE RD07(A) AS PER THE RD04? AND DO I NEED TO ORDER SEALED BEARINGS FOR ALL THE BEARINGS?
MANY THANKS:thumbup:
Wing Commander
I am pretty certain they are the same for each bike
BLUE 1999 xrv750x
thanks whealie.....can always rely on you...:thumbup:
any ideas on the dust seals??:rolleyes:
ALWAYS go for double sealed bearings on wheels. Since you're at it, change the rubber seals on the wheel as well. If your wheel spacers are marked in a way that even new seals wont..:confused:..seal, have new spacers machined in stainless. When assembling, rub everything with lithium grease (Red waterproof grease) and you should have bearings for another 100K miles.
HI ALL,
Just a point, no need to get bearings from Honda, you can get top quality bearings from a bearing outlet (SKF or Timken) they have then on the shelf so you dont have to order them usually.
