Does anyone know how to change the wheel size on the dash display to my 950 Adv, I have gone from 21 to 17 and the speedo is way out when compaired to the Sat Nav.........help
nicked from orange crush on ADV........
Turn key on
* Press Mode until the F display comes on
* Press and hold both the Mode and Set buttons for ~ 10 seconds.
* Wheel size will appear on the display
* Press Mode to toggle between 21, 19, and 17
* Select 19 or 17
* Press the Set button
Speedometer is now accurate, but Odometer is not.
out of interest, why have you fitted a 17" wheel to the front?
Bob.
Cheers for this Boboneleg, sorry for the late reply , been away!
I have not fitted the 17 inch front BUT the speedo was far more accurate set at 19 when i was running a 21 inch so thought that 17 may work better with my new 19 inch front?????
I will try tonight to set up the dash and reply later in the week re the results, cheers again:thumb:
You going to H.U.L this year???
SPG
Well that works !
when i ran a 21 front i had the dash set to 19 and it ran fairly true with the Sat Nav , now i am running a 19 front which on the speedo was 8 to 10 miles per hour out to the Sat Nav, I have now changed it to a 17 front on the dash and at 70mph she is only 2 mph slow compaired to the Sat Nav.
