hi all i've recently posted about a misfire on my RD03, i've eliminated coils/cdi and was going to take the carbs off/apart next weekend. i was lookind around things today looking for kinked fuel pipes etc, when i noticed a "y" piece with no pipe attatched coming from the fuel pump.
It may be nothing and only a vent pipe but its worth an investigation, if you go to the tech section fiche on the RD03 its on page 36 and is part 46. there are two part 46's and i have the one attatched that goes down to the floor but it shows a pipe coming off the y pice that goes "up", but to what ?? i would have thought it was only a vent pipe but does anyone know for sure before i start to strip everything down to find out its nothing
I'm hoping this is the needle in the haystack but nothing is ever that simple is it
I was thinking along the lines of fuel pump also, it has a standard one on at the moment and the clock is reading 50,000 km. it seems to pulse at about 24 per minute on tickover and gets slightly faster as you increase the revs but its impossible to tell over 2000 revs as theres so much other vibration going on.
Is there a diaphram in the original pump ? as i was thinking along the lines of its fine when pumping at low speeds but doesnt pump at full pressure at high revs??
Do straws and clutching spring to mind
I think carbs off is the first avenue to explore but would you be thinking of replacing the fuel pump anyway before it leaves me stranded somewhere as it could well be 20 years old.
Your thoughts on any of the above please
Ian
Ian
