After all the parts I have taken off and put back on I am stuck with this little bracket. I did put a label on it saying sprocket cover, but I can't see in any place it will fit. I'm pretty sure it's somewhere near the drive sprocket cover but as I've said ??
I've also looked at some different drawings and neither show the thing.
I'd hazzard a guess that it bolts to the engine case & keeps (neutral, oil press, stator?) wires away from the front sprocket.
I have a picture but cant post it for some reason. So if you look at the front sprocket as a clock face there is a small bolt at about 10 o,clock that holds that little bracket, it in turn holds back a wore to prevent damage from muck and gunge. It is not attached to the outer chain guard at all.
I can email a pic if you send an email address.
Ben
Thanks to both of you for the pictures. Looks like there are two similar brackets in different places. I know there is only one on mine so will have a look where this one goes.
Cheers.
