hi.. im new to the forum and hope i can get some help on here.
i just got a nx650 that had been stripped for painting and was never put back together,
i am having trouble getting a spark,, at the cdi i have 6 wires but all the wiring diagrams i have seen only show 5?
i have a 4 block connector with blue/yellow, green, black/yellow, yellow/red
and 2 block connector with green/white and black/white.
can someone please let me know where they should be going to ,i dont really want to start sticking them in without knowing.
also have a connector under the clocks with a black wire and yellow wire ,where would that go??
also is there a simple way to bench test starter relay to makesure its ok thanks
thanks for that ,, at least it shows the 6 wire unit and being in colour helps a lot.
looks like the green/white might be a secondary ground from the cutoff circut
Thanks for the replys,, i now have the bike running sweet ,, i do have to jump the starter relay as it doesnt seem to want to do anything so i will be taking it off and trying it on the bench
