Hello everybody, and greetings from Finland! I have been reading a lot in this forums before, but today I decided to make my own profile. (Sorry my english)
Today happened something that has happened to me once before. I drove my XL650V in hard sidewind. I think I can call it a storm. In the middle of a sharp curve when the wind blew from the right side, the bike lost power totally. Engine did not blow out, but rpm´s fell. I gave it more gas and accelerated, and then it responsed normally. Several times when I was hit by the powerful wind, the bike lost power. Has anybody else had this kind of issue? What can it be?
Hi and welcome
That sounds a strange problem and certainly not normal.
Perhaps have a look to check the carb breather pipes are connected and routed properly.
As I recall, a pair (from the float bowls) terminate alongside the underseat storage compartment under the sidepanel - there is a band of foam, presumably to prevent wind affecting them.
Also, from the top of the carbs there are 2 more breathers that run to a sub air filter, it's not unknown for this foam to disintegrate and disappear.
I can't think of anything else that would cause a momentary loss of power with a gust of wind.
Hello!i drive a Honda ntv 650 revere and have the same problem,the engine Loose power when strong wind from right side,did you find the problem with your transalp.
Had the same problem. On mine it was one of the hoses that is hanging under the bike that was off to left side. Whenever I had strong winds or put my foot in a resting possision, the bike we sour. Took me a whole summer to figure out :ROFLMAO:
