Just tried to start my XL700 after a few months in the garage. Battery is fully charged. After inserting the key and turning it to the on position nothing happened. Moving it a degree or two anticlockwise the lights came on as usual and it started fine. Jiggling the key a bit while the engine is running turns everything off. Now I'm paranoid about it randomly turning off when I'm riding if vibrations move the key to a position it doesnt like. I assume this is wear in the ignition barrel. Would anyone be able to confirm the liklihood of this before I embark on a very expensive replacement? Praying there could be some other reason with a simple fix! Cheers.
